1995 Acura Integra putting on the tranny
AIMEEKEYS
  • 1995 ACURA INTEGRA
  • 4 CYL
  • FWD
  • MANUAL
  • 155,000 MILES
Hi there-
from a complete stop putting on the tranny (in first) the car will hiccup like its going to die, in all other gears its fine.
I tested this out and it turns out it happens when the car is just started up and once warmed up if I let off the clutch before 1.5 rpms
It doesn't feel like its slipping but it does feel like a pretty good shake-
it is not a as bad of a shake as if you are coming to a complete stop and didn't put your clutch in so the car doesn't die
Thursday, October 29th, 2009 AT 11:47 AM
KHLOW2008
  • 41,814 POSTS
Hi Aimeekeys,
The symptoms described seems to indicate an engine ignition problem rather than the clutch.
Check the spark plugs and test the wires resistance.
Is the Check Engine Light showing?
Thursday, October 29th, 2009 AT 12:50 PM
AIMEEKEYS
No check engine light.
Ignition? Hmm.
Thursday, October 29th, 2009 AT 1:00 PM
