1995 Acura Integra oil in cylinders 2&3
107,136 MILES • 4 CYL • FWD • AUTOMATIC
ESTRIBOR92
Recently found that my oil is leaing somewhere. and that somewhere is in my engine. and I recently took my spark plug heads and found oil in cylinders 2&3. any help on what i can do thanks
Oct 26, 2010 at 12:52 PM
KHLOW2008
  • 41,812 POSTS
Hi estribor92,
Oil in the plug tubes means the plug seals under the valve cover are bad and has to be replaced to rectify.
Valve cover gasket and bushes would be recommended to be replaced together.
Oct 27, 2010 at 3:14 AM
