1995 Acura Integra my s3 light on my integra
JEBIDIAHUGHES
1995 Acura Integra 4 cyl Two Wheel Drive Automatic
my s3 light keeps blinking and wont let me start my car i did research and found that i had to look under near the peddles to a red flashing light that flashes a code i did and the code is 2...3...7...8...1... then repeats in a cycle what does this mean?
Jun 26, 2010 at 8:19 AM
KHLOW2008
  • 41,812 POSTS
Hi jebidiahughes,
With so manu codes on, there are apossibility of errors on things other than the items indicated.
When engine could not be started anf the S3 light is blinking, the most common fault would be the PGM-FI main relay and/or PCM.
Check if the fuel pump is working when the ignition switch is turned ON.
Jun 26, 2010 at 7:44 PM
