My problem is my car just recently wont go anywhere...and what i mean it wont go anywhere is that it starts up just fine and idles just fine....as soon as i put it into gear and step on the gas...i go like 2mph and the car is bogging at barely 2rpm's with the pedal to the floor!!!! The car ran fine previously, radiator just broke, so i replaced the radiator and thermostat, flushed the lines...put everything back together and now it does this!!
here is what i've done up to this point:
replaced radiator
replaced thermostat
replaced hoses
flushed coolant
replaced ALternator belt
checked spark plugs and found a LOT of OIL in cylinder
so changed valve cover gasket and spark plug seals
(no oil in cylinder since)
changed spark plugs
new distributor cap and rotor
did compression test with normal results (all 4 cylinders around 160psi)
I've suspected it could be something to be with the fuel...possible fuel filter, or fuel injector clog however the car starts up and idles fine....even when i gas it, it doesn't really go anywhere, but it doesn't ever die out...so im thinking it's not any of those....
can someone PLEASE HELP...im so stumped, im pulling my hair out!! I really can't figure out why its doing this.......
replaced radiator
replaced thermostat
replaced hoses
flushed coolant
changed spark plugs
Jun 30, 2009 at 3:10 PM
