1995 Acura Integra Motor won't redline
1995 ACURA INTEGRA
TCLOPEZ325
Engine Performance problem
1995 Acura Integra 4 cyl Front Wheel Drive Manual
I havnt started my car in 1 month and now that i start it it will not reach redline it will him 3500 RPMs and the redline is 7000 RPMs. I cannt find no fuel or vacume leaks. All conncetions are on and the battery keeps dieing for some reason also. I just cannt figure it out.
Nov 9, 2008 at 10:56 AM
KHLOW2008
  • 41,814 POSTS
Hi tclopez325,
A bad Throttle Position Sensor or low alternator charging rate would cause what you described as the ECM/PCM is not getting the correct voltage reading to act accordingly.
I would suggest testing the charging rate frst.
Nov 9, 2008 at 11:59 PM
F4I_GUY
  • 3,302 POSTS
Your ECU might be in limp mode.
Any on-board lights on your dash illuminated? MIL/CEL?
If not, to reset your ECU on your car just simply disconnect the negative terminal for a minute or so and pull the ECU fuse. It may be labeled "ECM F/I".
Nov 25, 2008 at 9:13 AM
