1995 Acura Integra Loss of Horsepower
JDADAMS
Engine Performance problem
1995 Acura Integra 4 cyl Front Wheel Drive Manual
My 95 acura integra has lost its peppyness lately. When I punch the gas, it just isn't responding like normal. My neighbor thought my rotor looked corroded where there might not be adequate contact. The guy at Checkers made a little more sense that it could just be the fuel filter. Any ideas?
Jun 7, 2009 at 12:59 PM
CARLIFE65
  • 200 POSTS
sounds like it could be your air filter is clogged, and maybe your catalytic converter is bad.
Oct 26, 2009 at 5:10 PM
JIMMYL645I
  • 39 POSTS
1)If you have not performed a tune up recently , then I'd get started with that first.
2)Replace Air Filter ( like last guy said )
3)Try Using a couple bottles of Shell-V fuel injection cleaner or STP fuel injection cleaner it should help with alot of carbon build up in the vavles , piston tops , and so on. Also clean injector's mean it will perform at its peak.
4)Get a new Fuel Filter put in if its been in there for a while.. you dont want to mess up your fuel pump.
other than that if it continues after a good tune up and all the above, you definately wanna ask a mechanic in your area to take a look at it.
hope its not too serious / easy fix* good luck man
JimmyL
oops- oh yea if you are running a LS/GS I know the recommendation is 87 octane which is enough but try using 91 octaine or 93 whichever you can get and run a higher octane gas to clear everything out of your car. ( 100,000+ )
Nov 2, 2009 at 10:20 AM
