1995 Acura Integra integra smoke
91,000 MILES • 4 CYL • FWD • MANUAL
ACURA101
hi i have a 95 gsr v-tec and when i run ritch "high rpm's' i only run premium in it but it smokes and has a harsh small but i kno the smell is from the gas but is the smoke something sticking or going bad or is it normal thanks...
Oct 28, 2010 at 4:25 AM
KHLOW2008
  • 41,812 POSTS
Hi acura101,
Smoke under certain circumstances are normal but not if it smokes most of the time.
When weather is cold, some smoke would be visible from the exhaust, that is normal due to the damp atmosphere.
If the smoke is white and you have coolant losses and/or overheating issues, the smoke could indicate a bad head or gasket.
If the smoke is slightly grey in color, it is oil being burnt in the cylinders or getting yto the exhaust system.
If smoke is black, excessive fuel is getting to the cylinders and not being burnt completely.
Oct 28, 2010 at 7:15 AM
ACURA101
its more of a whiteish smoke and its pretty light it ant real bad just wanted to make sure nothing to worry about
Oct 28, 2010 at 7:26 AM
KHLOW2008
  • 41,812 POSTS
If you do not have any coolant losses or overheating issues, then it is nothing to worry about. The engine has aged and valve seals and piston rings are slightly worn resulting in oil getting to the cylinders or exhaust system.
Engine is not going to fail immediately and except for a little oil consumption, it is still going to run well.
Oct 28, 2010 at 7:38 AM
