1995 Acura Integra engine runs rough after it warms up
1995 ACURA INTEGRA
150,000 MILES • 4 CYL • 2WD • MANUAL
BUSTERFR
when motor is warmed up motor will idel then it will die right down then it will idel back up like is starving for gas or spark this is agsr vtec
Sep 3, 2008 at 4:44 AM
KHLOW2008
  • 41,814 POSTS
Hi busterfr,
The idling circuit is not working properly. You need to check for vacumn leakages and air passage clogging.
Give the throttle body and IAC a good clean up with carb cleaner and the problem should be resolved if there are no vacumn leakages.
Sep 4, 2008 at 2:23 AM
