1995 Acura Integra Engine consuming oil
270,000 MILES • 4 CYL • 2WD • MANUAL
STENTON7600
I am having to change oil every 2000 miles. The engine seems to consume lot more oil on long drives (> 70 miles). I dont see any oil spots in the driveway. The engine seems to be running fine except that it idles at 500 - 800 rpm after its warm. i dont see anything extraordinary in the exhaust color. Any suggestions as to what the problem may be?
Feb 19, 2010 at 2:42 AM
KHLOW2008
  • 41,812 POSTS
Hi stenton7600,
At the mileage, the most common fault is oil consumption due to worn valve seals.
Feb 24, 2010 at 6:51 AM
