1995 Acura Integra cooling fans don't turn on at all
1995 ACURA INTEGRA
BAM671
Engine Cooling problem
1995 Acura Integra 4 cyl Front Wheel Drive
i've noticed that my cooling fan doesn't kick on at all when i'm driving or if i let it idle... it used to before bt shortly after i changed the distibutor, starter, and altenator it doesn't turn on when it needs to... even my a/c doesn't work now... it all happened after those changes were made... please help me solve this problem...
May 22, 2009 at 10:43 AM
Check the coolant temperature sensor and engine temperature gauge switch/fan relay and fan motor itself
May 22, 2009 at 10:49 AM
F4I_GUY
  • 3,302 POSTS
A quick tip would be to jump the fan switch connector (2 pin connector on the thermostat harness). If the fan turns on, the switch is bad.
May 23, 2009 at 12:34 AM
