1995 Acura Integra Cooling fan not coming on
135,000 MILES • 4 CYL • 2WD • MANUAL
CSAMUELS
I have a question my acura integra just started over heating i had trouble shooted it before and i got it to stay cool for about 2 weeks every time i drive or rev the car it will sty cool if i keep my rpms up the car wont over heat i checked all of my fuses and changed the cooling fan relay as well as the ac relay and still nothing radiatior cap seems to be fine ..i just dont understand what it can be?
May 22, 2009 at 7:58 AM
F4I_GUY
  • 3,302 POSTS
Well does the fan come on?
If not, check all your fuses, then try jumping the 2pin connector on the thermostat housing (the fan switch). If the fan turns on with the key on RUNII, then the switch is faulty.
May 23, 2009 at 12:35 AM
