1995 Acura Integra cooling fan
1995 ACURA INTEGRA
130,000 MILES • 4 CYL • FWD • MANUAL
JFRIAS69
Car overheating Cooling fan does not turn on when car gets hot
I've replaced thermostat & temp sensor but same results. Fan does turn on when I turn a/c on though
Do I need cooling fan switch? and where is it located?
Aug 23, 2008 at 5:56 AM
KHLOW2008
  • 41,814 POSTS
Hi jfrias69,
Depending on engine type, the thermo fan switch should either be located on the thermostat housing or on engine block near to oil filter, (under the intalke manifold)
Check if its wires are dislodged, if you bridge the terminals, the fans should work when ignition switch is turned on.
Aug 25, 2008 at 2:19 AM
