1995 Acura Integra 5th gear shakes
1995 ACURA INTEGRA
149,969 MILES • 4 CYL • 2WD • MANUAL
SONOFAMITCH
when driving my car i noticed that my 5th gearr shakes. all other gears are fine but the 5th gear jerks alot
Apr 5, 2009 at 8:50 AM
F4I_GUY
  • 3,302 POSTS
What shakes and wobbles?
The chassis? Steering wheel?
Apr 5, 2009 at 11:03 AM
TED-E-DEE
  • 109 POSTS
Can you get the frt. of you car in the air ? If you can access the underneath of your vehicle, ck. the end cover of your trans. , if there is an oil leak around your end cover, you could be losing 5th gear. 5th gear is higher up than all the other gears & if the end cover or if there is a trans. leak anywhere for that matter, 5th gear is the 1st to go. You may be able to replace the 5th gear assy. w/out removing the trans. . When you remove the end cover, it's right there. Might have to remove trans. mount bolt & lower engine/trans. to remove the assy. from the shaft. Good Luck. I hope it's smoehing much easier. I have done several of 5th gears though, so I thought I would send ya the info.
Apr 26, 2009 at 12:28 AM
