1995 Acura Integra 1995 Integra Speedometer not working
100,000 MILES • 4 CYL • FWD • MANUAL
BENBEN23
Hi my 1995 integra gsr manual trannys speedometer isnt working the tach works for rpms, just the mph doesnt work what could be my possible causes thanks[img:e699bd74bf]http://www.2carpros.com/forum/automotive_pictures/412467_car_034_1.jpg[/img:e699bd74bf]
Sep 22, 2009 at 5:52 AM
KHLOW2008
  • 41,812 POSTS
Hi benben23,
Most probably the Vehicle Speed Sensor is faulty. Check the wiring connector of the VSS located on trans axle below the throttle body and just behind the thermostat housing.
Sep 22, 2009 at 6:31 AM
BENBEN23
Thanks for the response im most certain thats what the problem is as when I pulled it, it was very corroded, im gonna try to clean it and see if that works
Sep 22, 2009 at 7:36 AM
KHLOW2008
  • 41,812 POSTS
You are welcomed.
Hope it is only the wires which could be rectified with some cleaning and if possible, apply some die electric grease to prevent further corrosion and oxidation.
Sep 23, 2009 at 1:30 AM
