1994 Acura Integra Radio Display Out
OOSYSTEMOO
Last night i was driving and out of no where my radio and my time display on the dashboard just turned off, so randomly. I checked the fuses and its not those. I dont know what else it could be could u please help me out!? it would be greatly appreciated thanks
eric
Sep 24, 2007 at 9:11 AM
2CARPRO JACK
  • 11,533 POSTS
Check fuse #32 in the underhood fuse block and re-check fuse #23 in the under dash fuse block, use a test light so you can verify power coming in to the fuse as well as going out
Sep 25, 2007 at 12:42 AM
Suggested Repair
Recheck underhood fuse #32 and under-dash fuse #23 with a test light, verifying power both into and out of each fuse.
Conversation Summary
The owner of a 1994 Acura Integra reported that the radio and dashboard time display shut off suddenly while driving. The owner had already checked the fuses and believed they were fine. The expert advised rechecking fuse #32 in the underhood fuse block and fuse #23 in the under-dash fuse block, using a test light to confirm power both entering and leaving the fuses.
