1994 Acura Integra Won't kick over
213,000 MILES • 4 CYL • 2WD • AUTOMATIC
TRIGGERS8011
Replaced battery, started right up. went to gas station and filled up. would be restart, kicking over but no spark
Dec 26, 2009 at 2:40 AM
KHLOW2008
  • 41,812 POSTS
Hi triggers8011,
Under no spark conditions, you would have to check the distributor.
Is there battery voltage at the distributor Black/Yellow wire with ignition switch turned ON and while cranking ?
Dec 26, 2009 at 2:59 AM
