Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Acura
Integra
Ignition
No Spark
1994 Acura Integra Won't kick over
1994 ACURA INTEGRA
213,000 MILES • 4 CYL • 2WD • AUTOMATIC
TRIGGERS8011
MEMBER
1 POST
Replaced battery, started right up. went to gas station and filled up. would be restart, kicking over but no spark
Dec 26, 2009 at 2:40 AM
KHLOW2008
Experienced Mechanic
Hi triggers8011,
Under no spark conditions, you would have to check the distributor.
Is there battery voltage at the distributor Black/Yellow wire with ignition switch turned ON and while cranking ?
Dec 26, 2009 at 2:59 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
