Started over a year ago. When the weather cools the idle rises and falls wildly. At traffic lights I have to put it in neutral to be able to stop safely.
First I removed the idle control and cleaned it thoroughly thru the screen. When that didn't work I replaced it with a used idle control. When that didn't work I removed the large hose going back from the air filter and thoroughly cleaned the butterfly. Still no change. When I start the car in the morning the idle screams so high you would think the car is about to explode.
What do I do?
What do I do?
Jan 7, 2010 at 11:45 AM
