How do I know if my car has jumped time?
i was driving it went dead and and will not start. Batt is good and its getting gas. Bealts turn still will not crank. Please help
Wednesday, October 1st, 2008 AT 6:50 PM
KHLOW2008
MECHANIC
Hi Hope Toole,
Remove the distributor cap and crank the engine. If the rotor turns, the timing belt should be okay.
Check for sparks from the ignition coil when cranking.
