No crank/no start
240,000 MILES • 1.8L • 4 CYL • FWD • MANUAL
GBAKER550
I have a 1996 Acura Integra GSR 1.8L, stick. It won't crank or start or turn over. Nothing happends, but when you turn the key over all the lights come on in the dash. I have replace the starter, altenator, main relay, and the fuel pump. I had to relpace the altenator because it started smoking. Now after I replace all of those parts I still have nothing turning over the car. Had the Battery tested and it is good and the terminals are clean and tight. Is there anything I am missing. I need help trying to get this car to crank and run. Thanks
Mar 2, 2016 at 11:24 AM
CATAFINA
  • 167 POSTS
It could be a blown a fusible link check it out then let us know.
Mar 2, 2016 at 1:38 PM
GBAKER550
I dont see any fuses or links blown. That was the first thing I checked.
Mar 2, 2016 at 10:36 PM
HMAC300
  • 48,601 POSTS
try resetting security system if no manual look online for your car. also try another key if you have one.
Mar 3, 2016 at 1:38 AM
