1994 Acura Integra Sway Bar Broke
184,000 MILES • 4 CYL • FWD • MANUAL
DAVEHOWARD6245
I took my car to get inspected and it failed from an apparent cracked headlight (that I can not see) and then he said that the sway bar was broken in the front and back. I thought a sway bar was a performance part to keep your car level through turns and did not come stock. he is estimating 800 dollars in repair. Is this right?
Jun 23, 2009 at 7:14 AM
F4I_GUY
  • 3,302 POSTS
Your vehicle does have stabilizer bars. And they are required for a safety inspection.
$800 sounds about right if the headlight(s) is included. If $800 is just for the bars and labour, you can find it cheaper somewhere else.
Jun 23, 2009 at 10:04 AM
