1994 Acura Integra starting when hot or driven long distanc
119,487 MILES • 4 CYL • FWD • AUTOMATIC
WEEKEND
Car works very well, very well maintained, usually starts just fine. However, when the car has been running in hot weather and is turned off, it won't start, even after 10 or 15 minutes. It will start only if jumped. Then, later, it will start fine again. Never happens in the winter.
Sep 8, 2010 at 3:12 AM
KHLOW2008
  • 41,812 POSTS
Hi Weekend,
Thank you for the donation.
This is a peculiar problem and the only logical explanation I can think off is a faulty battery.
If your battery is the maintenance free type, then it is likely to be the cause. Hot weather would affect the battery performance and it could fail intermittently due to internal faults.
When problem occurs, perform a battery condition and high rate discharge test and let me know the results.
Jan 24, 2017 at 1:08 PM
WEEKEND
first, it is not a maintenance-free battery. The battery has been checked several times and was always fine.
It is not a battery problem. I have heard this happen to other Acura owners, but no one seems to have found a reason. I had hoped you would.
KHLOW2008
  • 41,812 POSTS
Personally those that I have encountered are all maintenance free batteries and they can work well one moment and the next time you would not be able to restart and suddenly you would be able to start again.
When jump starting works, it means the battery is not providing sufficient draw to start and if it is not due to a faulty battery, then it should either be a poor ground or power supply connections.
Have you ever tried to clean and re-tighten the grounds and fuse box main fuse connections?
Were the charging rate tested when problem occurs?
