1994 Acura Integra No Power to car
150,000 MILES • 4 CYL • 2WD • MANUAL
1994 INTEGRA GSR
I just bought this car and everything was working great when i bought it. I brought it home and noticed that the electrical connections to the battery were corroded so i took them off, cleaned them and reinstalled. NOW NOTHING WORKS! the headlights work, horn, heater fan but nothing else. There is an alarm installed. I checked underhood fuses by checking continuity, the battery is at 11.8v, i checked the ground to the battery by putting pos (of voltmeter) on battery and neg on engine block and got 10.8v. I have the wiring diagram for the car and everything works thats before the 100amp main fuse, but that fuse "seems" to check out. I tried 2 sets of keys. I hear a relay click when i turn the key but no dash lights come on. I dont understand, im going to continue to look at the wiring harness but how could this happen? all i did was clean the connections. Dead ecu? alarm immobilizer? fried harness? ground somewhere? bad battery?
Dec 3, 2008 at 10:19 AM
F4I_GUY
  • 3,302 POSTS
Is this a factory security system or aftermarket?
Immobilizer?
Usually a security system will not affect the cluster illumination, so I'd probably take a second look at the connections. Are you sure you cleaned them very well? Are they tight? It is crutical that they are tight.
Dec 4, 2008 at 1:38 PM
