1994 Acura Integra how to repair it my self?
FLEON508
1994 Acura Integra 4 cyl Two Wheel Drive Manual
I have an idea on how to do this but i need to be sure. Can you please tell me how do I change the o ring on my distributor? And as that the only thing i should look for?
Aug 30, 2008 at 8:36 AM
KHLOW2008
  • 41,812 POSTS
Hi fleon508,
Oil leaking can be from the O ring and distributor seal inside.
Remove distributor cap.
Note position of Rotor.
Mark distributor position before removing 3 pcs of holding bolt. (Use this mark to reinstall to prevent ignition timng from getting off mark.)
Disconnect wire sockets.
Aug 30, 2008 at 6:19 PM
