1994 Acura Integra Engine stall and distributor rotor does
1994 ACURA INTEGRA
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
QWYANGXIE
My car stall when driving. After series of diagnostics, I have reached the step to look at the distributor because of no sparks in spark plug. After removing the distributor cap, I crank the engine. The distributor rotor does not move. Do you think it is timing belt problem? BTW, the water pump belt runs. Thanks.
May 4, 2008 at 6:32 AM
Could be the distributor drive gear sheared off or the timing belt got loose or broken
May 4, 2008 at 8:46 AM
