1994 Acura Integra Dive Axle Removal
129,000 MILES • 4 CYL • FWD • AUTOMATIC
T711829
Trying to remove the drivers side drive axle from my 94 integra, automatic.. I have the outer joint separated from the hub. The inner joint is connected to a half shaft. My manual says to pry it loose. I have tried but the axle will not separate from the half shaft. Am I missing something ? Suggestions ?
Thanks - Terry
Dec 26, 2007 at 5:01 AM
MERLIN2021
  • 17,250 POSTS
The driver's side usually plugs into the tranny? Use two pry bars and pop it out, the entire axle assy.
Dec 26, 2007 at 5:11 AM
T711829
[quote:f317bbc6ac="merlin2021"]The driver's side usually plugs into the tranny? Use two pry bars and pop it out, the entire axle assy.[/quote:f317bbc6ac]
On my '94 the drivers side goes into a half shaft, the half shaft goes into the tranny. I've been trying to "pop" it loose from the half shaft with no luck.
Thanks - Terry
Dec 26, 2007 at 6:22 AM
T711829
[quote:3044600d76="t711829"][quote:3044600d76="merlin2021"]The driver's side usually plugs into the tranny? Use two pry bars and pop it out, the entire axle assy.[/quote:3044600d76]
Thanks - Terry[/quote:3044600d76]
I'm sorry - when I say half shaft I mean intermediate shaft.
terry
Dec 26, 2007 at 7:35 AM
MERLIN2021
  • 17,250 POSTS
If the outer is the only joint you need, replace just the outerjoint and boot, Unless you can see a shear pin, or snap ring holding the axle to the intermed shaft....
Dec 26, 2007 at 12:31 PM
