1994 Acura Integra A/T only shifts manually
130,000 MILES • 4 CYL • FWD • AUTOMATIC
JCAPPSVA2006
I have an Acura that will ony shift gears manually with an automatic trans. I changed the computer with no change in the performance, the solenoids seem to engage but when testing the pig tails I cannot find power. I believe something electronic is not feeding the proper information to the TCM (if at all) but there are no good diagrams to show me where to check next. Do you have any suggestions?
Jan 24, 2010 at 7:48 AM
KHLOW2008
  • 41,812 POSTS
Hi jcappsva2006,
Did you try to retrieve for trouble codes?
Jan 25, 2010 at 12:43 AM
