The check engine light is on and at 3 1/2 RPM's the car shakes and you can't go past 3 1/2 RPM's. What's wrong with it?
Aug 7, 2010 at 12:11 PM
KHLOW2008
✓Experienced Mechanic
Hi LoganGold16,
Get the trouble code retrieved to understand if the CEL is related to the problem.
Bridge the SCS and turnignition switch ON.
Count the blinking of the CEL to get the code.
Quick blinks = 1.
Prolonged blink = 10.
Aug 8, 2010 at 2:18 AM
LOGANGOLD16
MEMBER
On the connecter there is only a 1 and 3 pin there is nothing in the 2nd spot.
Aug 9, 2010 at 3:30 AM
KHLOW2008
Check if the wire is hanging around somewhere. Some one took it out and did not put it back in position.
Aug 9, 2010 at 4:10 AM
LOGANGOLD16
MEMBER
There's a yellow plug. It has three holes the one in the middle has nothing. and then in the back of the plug the two wires are leading to the 1st and 3rd hole. There is no chords or anything unconnected
Aug 9, 2010 at 4:41 AM
KHLOW2008
That is not the correct comnnector. It is for plugging in preOBD-II scanners.
Look for another coupler nearby with only 2 pins and wires. It could be tucked up somewhere in the wireharness.
Aug 9, 2010 at 4:48 AM
LOGANGOLD16
MEMBER
The code is 3 and 4. Code 3 stood for MAP sensor and 4 is reporting a misfire. Checked the power out of it and 5 coming in and 2.85 volts coming out. Changed spark plugs wires and rotor. No help, Slaved in new throttle assembly that didn't do anything different.
Sep 16, 2010 at 1:42 PM
KHLOW2008
Code 3 = MAP sensor. Check the wiring and vacumn hoses. Honda MAP seldom fails though it can occur.
Code 4 = Crank Angle Sensor, not a misfiring. Crank sensor is in distributor and if faulty, you would have to replace the distributor assy.
