1994 Acura Integra access to antenna mask motor
185,000 MILES • 4 CYL • FWD • AUTOMATIC
JPHONG70
Hello.
I just wanted to know how to get access to the Antenna Mask motor. I just bought a new antenna mask to install, but I think the old white tooth line broke off and is still in the motor. How to get access to it so I can remove the broken pieces?
Thanks.
Aug 7, 2008 at 1:17 PM
KHLOW2008
  • 41,812 POSTS
Hi jphong70,
You need to remove the antenna mast locknut and motor holding bolt in luggage compartment.
Aug 8, 2008 at 1:06 AM
JPHONG70
Yes I have a diagram regarding the bolt at the bottom of the motor, but how to I get access to the motor. I have a 1994 Acura Hatchback. How can I get to the motor?
Do I have to take off the inside plastic panel in the car? If so, how?
Do you have a diagram or picture?
thanks.
Aug 8, 2008 at 6:41 PM
KHLOW2008
  • 41,812 POSTS
Hi jphong70,
You need to remove the plastic panel to get at the motor. Pull the clips out and the panel can be moved aside.
Aug 8, 2008 at 10:51 PM
