1993 Acura Integra Solf Brake
1993 ACURA INTEGRA
150,000 MILES • 4 CYL • FWD • AUTOMATIC
KAY1
Most of the time while driving, brake is solf, feel like no air, it drepressed down almost to the wall, but sometime it seems normal, and sometime at a stop, brake pedal slip, like loosing air, if I don't keep pressing on it, the car moves, and I bleed it well, front & back, what could it be? could it be booster brake is bad?
Also, my car shakes, when comes to a stop, rpm is normal on 1 or litte under, but I don't think its rpm low, it make rumbling noise, shake, but as it moves little bit, it stop shake or wobbles, could it be motor mount or transmission wears? any suggestion?
Mar 12, 2010 at 12:53 AM
Replace the brake master cylinder and make sure you bleed it out thoroughly in sequence-also check the brake booster if its leaking
Mar 12, 2010 at 1:57 AM
