1993 Acura Integra Key wton't come out
148,000 MILES • 4 CYL • FWD • AUTOMATIC
KAY1
Most of the time, ignition key won't come out, unless I keep stepping on the brake pedal until I hear a sound of click that unlock the shift then the key comes out. So how/where to I check for failure? I checked the brake light switch by the brake pedal, it seems working fine, any suggestion where I should look?
Mar 11, 2010 at 5:01 PM
KHLOW2008
  • 41,812 POSTS
Hi Kay1,
Check the gear shift. Ensure the P indicator light is showing correctly when ignition is turned ON. If the indicator light is not showing, the key interlock is preventing the key from bing turned to the lock position to enable the key to be removed.
Mar 12, 2010 at 5:59 AM
