1993 Acura Integra integra squeals.
189,150 MILES • 4 CYL • FWD • MANUAL
TEGGYGSR_93
  • 19 POSTS
when i turn on my teggy its squeals a little bit, but when i sit in neutral it squeals until i put it in gear and drive off..my hood rattles too, any answers??
Mar 21, 2009 at 2:48 PM
KHLOW2008
  • 41,812 POSTS
Hi TeggyGSR,
I have diffuculty understanding your question.
After squealing goes off, does it come back when you come to a stop?
Does noise level change when accelerating? I would suggest checking the beltings, they might need some adjustment or replacement.
Rattling of the hood could be due to the hood supports separating due to cracked sealants plus a low idling speed and bad engine mounts.
Mar 22, 2009 at 2:54 AM
TEGGYGSR_93
  • 19 POSTS
yes my integra squeals when i come back to a stop, it gets louder at times, & at times it just goes away until another time.
Mar 22, 2009 at 7:07 AM
KHLOW2008
  • 41,812 POSTS
I would suggest checking the drive belts for wear and adjustment.
Mar 22, 2009 at 12:33 PM
TEGGYGSR_93
  • 19 POSTS
ok. i was thinking it was that, but had to get an answer from a certified person. thank you.
Mar 23, 2009 at 4:04 AM
TEGGYGSR_93
  • 19 POSTS
also when i drive i can hear a little rattle that sounds like metal against metal, like my exhaust is missing a hanger somewhere, but i only hear the sound when im driving and i take my foot off the accelerator and let the car coast.
Mar 23, 2009 at 2:37 PM
KHLOW2008
  • 41,812 POSTS
Where noise is concerned, it is never easy to diagnose without the physical car. You have to isolate or pin point the location of the source before we are able to help.
Rattling noise are usually due to loose plates and it could be from a detached exhaust heat shield.
Mar 24, 2009 at 2:18 AM
TEGGYGSR_93
  • 19 POSTS
now when i let off the clutch & accelerate in first & second gear the teggy gives off some light squeals.
Apr 7, 2009 at 1:19 PM
KHLOW2008
  • 41,812 POSTS
Yes, that indicates belting noises. Check the belting adjustments and crank pulley condition.
Apr 7, 2009 at 2:57 PM
TEGGYGSR_93
  • 19 POSTS
i was also wondering if a catalytic converter from a 91 integra ls would fit my 93 integra rs..they are the same gen, engine type, & size.
Apr 13, 2009 at 3:57 AM
KHLOW2008
  • 41,812 POSTS
Being from the same generation and model, they should be similar and applicable.
Apr 13, 2009 at 8:15 AM
TEGGYGSR_93
  • 19 POSTS
now when i turn on my ac, water leaks from uynder the dash on the pass. side??
Apr 20, 2009 at 10:13 AM
KHLOW2008
  • 41,812 POSTS
There is a hose for draining condensation water from the evaporator to outside the vehicle via the firewall.
Check if it is clogged or dislodged.
Apr 21, 2009 at 3:04 AM
TEGGYGSR_93
  • 19 POSTS
now my drivers side window wont go all the way up, it gets to a certain point then gets stuck, plus it seems like it is coming inward into the car instead of going right up into the joint of the door..
My windows are manual, roll them up myself..
Apr 26, 2009 at 12:20 PM
KHLOW2008
  • 41,812 POSTS
The regulators are failing. The brackets could be bent when excessive force is applied to wind it up. Try applying some silicone spray onto the run channels and if the movement smoothens out, you can stiil coax it to work for a while longer.
Most probably you would need to replace the window regulator and runchannels.
Apr 27, 2009 at 12:15 AM
TEGGYGSR_93
  • 19 POSTS
i was wondering how i could shorten my gears..i was racing a 2005 RSX and beat him in first and second, but my third and fourth gears are so long that he came back and passed..is there anyway of shortening these gears..
Apr 29, 2009 at 12:57 PM
KHLOW2008
  • 41,812 POSTS
Sorry, I am not into modifications so is unable to assist on this.
Just some info if it helps.
If you wish to be better than a car 12 years newer, it would involve increasing the power of the engine or you would have to change the gear ratios, which is a costly thing.
You would need to get a dyno test and provide the necessary data and then plot how it is going to be for the engine or trans. By the time the work is done, the other car might not be around for you to race anymore.
Apr 30, 2009 at 12:10 AM
TEGGYGSR_93
  • 19 POSTS
i had the worst luck today...i was driving and something flew off the back of an open-back truck, and put a hole in the bottom left corner of my engine(the block).. i was wondering if i could just replace the engine block, or if its smarter to get a whole new engine.
May 7, 2009 at 11:51 AM
KHLOW2008
  • 41,812 POSTS
A complete engine would save you lot of time and trouble. It should be cheaper as replacing of block requires gasket sets.
May 8, 2009 at 5:14 AM
TEGGYGSR_93
  • 19 POSTS
now im gettin my engine replaced and thinking about gettin a b20 put in, is there anything special(change motor mounts, ecu) i would have to do to get a b20 put in?
May 11, 2009 at 3:44 AM
KHLOW2008
  • 41,812 POSTS
Sorry, I have never done this before so is unable to provide much info.
I have heard of B20 engine blocks with B16A heads modification. But problem is the engines keeps disintegrating when pushed to the limits.
Not sure of the B20 type you are refering to and ECU would depend on if it is equipped with VTEC.
May 11, 2009 at 11:44 PM
TEGGYGSR_93
  • 19 POSTS
im back, you helped so much last time and i know u can help this time.
i recently got my motor swapped, and i installed a tach, but now my radio cuts off as soon as it comes on, its getting power because i can still eject and input cds, it just wont stay on and i cant turn it on, plus my tach wont work because its ran threw the ground wire threw the cd player, is it a ground wire problem or something else?
Jul 5, 2009 at 1:44 PM
KHLOW2008
  • 41,812 POSTS
Sounds like a grounding problem
Check the ground connection behind left side of dash at steering column.
If you have a tachomater, you can attach it to the distributor blue wire, there should be a link near the wheel strut tower, and test if pulses are present. If the ignition coil is bad, the tachometer would not work .
Jul 6, 2009 at 2:18 AM
TEGGYGSR_93
  • 19 POSTS
now i solved that thanks to you i was wondering now, do i hook the green wire from the tachometer to the rpm signal on the ecu or the speed signal??
Jul 7, 2009 at 12:16 PM
