I have changed the two bushings that come in the kits that I have found and the gearshift still feels like in neutral when in gear, and suggestions?
Jun 3, 2009 at 1:56 PM
2CARPRO JACK
✓Experienced Mechanic
You changed the bushings at the shifter? If so you need to also look at the ones where they attach to the trans.If the new bushings made no difference, then the problem must be at the trans
