1993 Acura Integra exhaust smell while idling or parked wit
107,480 MILES • 4 CYL • FWD • MANUAL
RALPHRENN
  • 5 POSTS
I have a 93 Integra. When the car is idling or at a stop light with the windows down. There's a smell of exhaust. Is there a leak from under the car? Please help!
Jan 26, 2008 at 6:08 AM
BRUCE HUNT
  • 3,754 POSTS
With the vehicle safely lifted, have a partner start the vehicle. Plug the tailpipe with a large rag pressed over the end of the pipe. Note the exhaust leaks under the vehicle. It should be a simple job. Determine if the cause is a gasket, rusted pipe, hole, etc. That will dictate how you fix the problem. Don't forget to look under the hood as the problem could be at the exhaust manifold as well.
Jan 28, 2008 at 6:43 AM
