1993 Acura Integra electric fans
187,000 MILES • 4 CYL • FWD • AUTOMATIC
GTOWNJOE
  • 13 POSTS
I have replaced the electric fan relay, cooling fan switch,temperature switch,and thermostat. the problem is the electric fans still wont kick on.
Mar 25, 2010 at 11:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
have you tested the fans themselves to ensure they are good?
Mar 25, 2010 at 11:48 AM
GTOWNJOE
  • 13 POSTS
yes jumped one to battery an it works
Mar 25, 2010 at 12:22 PM
GTOWNJOE
  • 13 POSTS
also top radiator hose is hot but bottom hose that goes to the stat is not even warm
Mar 25, 2010 at 12:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
as far as the radiator hoses, that is how its supposed to be...warm coolant comes into the radiator, cools off, then goes back out the other hose, so one will be hot and the other cool.
for the fans, if the fan motors, temperature switch, radiator and condenser fan relays and the oil temperature switch are all tested OK, i would suspect a faulty fan control module.
Mar 25, 2010 at 12:35 PM
GTOWNJOE
  • 13 POSTS
whee is it located so i know what to look for
Mar 25, 2010 at 12:40 PM
BLUELIGHTNIN6
  • 16,542 POSTS
behind the center of dash, on the right side of the heater assembly
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_404.jpg
Mar 25, 2010 at 12:43 PM
GTOWNJOE
  • 13 POSTS
thanks I'll check it
Mar 25, 2010 at 12:53 PM
