1993 Acura Integra drivetrain vibration
200,000 MILES • 4 CYL • FWD • MANUAL
ROTARY12A
my acura vibrates only during acceleration and its 90% of the time not always. i have already gone thru the suspension and drivetrain and everything is tight. i replaced the axles three times already with diffrent manufacturers. i rotated the tires to no avail. my throw out bearing is whining. but the clutch engages good. have you seen anything like this before.
Dec 23, 2009 at 11:25 AM
KHLOW2008
  • 41,812 POSTS
Hi rotary12a,
Check the transaxle where the inner CV joints are attached. If there are excessive side play due to faulty differential bearings, vibrations would occur during acceleration.
Dec 26, 2009 at 2:53 AM
