1993 Acura Integra cruise control
NWKILLER
1993 Acura Integra 4 cyl Front Wheel Drive Manual
I'm trying to get my cruise to work, one thing I'd like to know is there a fuse that is linked to the cruise control? I have changed the cruise unit under the hood but it still don't work. I also noticed there is two cables that run to the gas pedel one for throttle the other runs to my cruise control unit. But when I pushdown on the pedel is the linkage suposed to move both cables at the same time? mine don't
Aug 10, 2008 at 10:48 PM
KHLOW2008
  • 41,812 POSTS
Hi nwkiller,
The cables work independent of each other.
Does the main cruise control switch lights up when it is turned on?
You need to check the brake switch and clutch neutral start switch for continuity. Check the pedal to switch clearance.
Aug 12, 2008 at 2:36 AM
NWKILLER
yes the the light works on the cruise button and thank you ill take a look at the switches you mentioned. Is there any adjustments to make on the brake or cluch switches or just check for cont
Aug 12, 2008 at 10:36 PM
KHLOW2008
  • 41,812 POSTS
Hi nwkiller,
THe pedal to switch clearance is adjustable and there should be a stopper which might have worn off.
Aug 13, 2008 at 12:56 AM
