1993 Acura Integra Cooling fans not turning on
227,000 MILES • 4 CYL • 2WD • MANUAL
CULIACAN00
Hi, I have a 1993 Acura Integra 1.8 engine, with a manual transmission. My problem is that my cooling fans will not turn on when the engine is hot. However, they do turn on when I use my a/c and I have also jumped the thermo switch to check if my fans turn on, which they do. I have replaced the thermo switch, temperature sending unit, coolant temperature sensor and thermostat. I have also tried bleeding the cooling system. Can a Fan timer control module be the problem? Any suggestions? Thank you for your time.
Apr 20, 2009 at 9:12 AM
DOCFIXIT
  • 18,828 POSTS
Hi
The switch you jumper to get fan to come on is it the ECT on front left side cylinder head? Have you change the Radiator fan relay right front behind head light near battery?
Let me know
Thanks for donate
Apr 21, 2009 at 2:29 AM
CULIACAN00
The connector I jumped was the sensor attached to the thermostat housing. No, I have not changed the radiator fan relay.
Apr 21, 2009 at 5:34 AM
DOCFIXIT
  • 18,828 POSTS
Does sensor you jump have a Yellow green and a black wire attached?
Apr 21, 2009 at 7:05 AM
CULIACAN00
Yes, that is correct.
Apr 21, 2009 at 6:53 PM
DOCFIXIT
  • 18,828 POSTS
Think the ECT sensor is faulty. Need Ohm meter at 68 deg. there is 2000-4000 ohms at 176 deg. 200-300 ohms. Check across terminals of sensor.
Let me know what you get
Apr 22, 2009 at 8:48 AM
CULIACAN00
Hi, so I replaced the thermo switch on the thermostat housing with a genuine honda part and still, fans will not turn on.
Apr 27, 2009 at 7:23 PM
DOCFIXIT
  • 18,828 POSTS
When you jumper the thermister and fans work indicates the system is functuional. You see the resistence drops as temp goes up and grounds relay.
Did you ohm switch as I described?
Apr 29, 2009 at 2:13 AM
