1993 Acura Integra Clutch
1993 ACURA INTEGRA
JAYDM
Transmission problem
1993 Acura Integra 4 cyl Two Wheel Drive Manual
Hi i just changed my clutch and also resurface the flywheel.. Now that everything is done and i go start the car and try to put it in any gear it wont go in. Well without it making the grinding noise. It only goes it gear when the car is not started.. Help please
Mar 22, 2009 at 2:37 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi jaydm,
Seems the clutch is not releasing to enable you to engage the gears.
Do you have enough clutch pedal height ?
Is the clutch fork travelling far enough?
Is there any clutch pedal pressure?
With gears engaged and clutch depressed, are you able to start vehicle without the vehicle jerking forward?
Mar 22, 2009 at 10:09 AM
