1993 Acura Integra battery
180 MILES • 4 CYL • FWD • MANUAL
VILLEVANG
i have a 93 integra gsr...i try to change the start but i was given the worng starter..so i put my old one back on... i hook everything back. i try puting the battery on but it spark up very big and it melted the battery thermal a little bit, it does it eveytime when i try puting it on, so pleases help asap!!!
May 16, 2008 at 10:07 PM
  • 31,937 POSTS
Check the battery is connected the correct way around neg (-) Earth and you have not got a short at the starter, as if this is all you disconnected in the first place, the problem will be here.
Mark (mhpautos)
May 16, 2008 at 10:13 PM
