1992 Acura Integra valve
SALTERBE
  • 1992 ACURA INTEGRA
Engine Mechanical problem
1992 Acura Integra 4 cyl Two Wheel Drive Automatic
How to clean, the valve system
Sunday, March 7th, 2010 AT 7:50 PM
KHLOW2008
  • 41,814 POSTS
Hi salterbe,
What valve are you referring to?
Monday, March 8th, 2010 AT 10:27 AM
SALTERBE
The motor velve, if there is a way to clean them. One of my motor valve is stock o else
Monday, March 8th, 2010 AT 6:41 PM
  • 31,937 POSTS
Hi there,
There is no real effective way to do this, if you have a compression leak via a valve, then the valve will need to be re cut as will the seat, the head has to be removed to do this.
Mark (mhpautos)
Monday, March 8th, 2010 AT 9:14 PM
SALTERBE
Is there a way to know if the problem is with exhaust or intake valve
Tuesday, March 9th, 2010 AT 7:54 AM
  • 31,937 POSTS
Hi there,
If you do an air pressure test, that is introduce low pressure compressed air into the cylinder with it at TDC, you will hear it leak out the exhaust or the induction, you will need a special adapter to do this, but in 99% of the case it will be the exhaust vale that is burnt as it rubs so much hotter, regardless all valves should be re cut or replaced as required with the head off.
Mark (mhpautos)
Tuesday, March 9th, 2010 AT 4:20 PM
