1992 Acura Integra over flowing
122,000 MILES • 4 CYL • FWD • MANUAL
1992B18INTEGRA
ok i put a thermostat in my car and a radator cap and my car is still gettin hot i have burped my car 3 times and it is over flowin into the over flow so much its comin out of it and makin all fluid come out of radatior and everytime it does this i put more fluid back in it and burp it a few more times and still have more problems y is that?
Dec 29, 2009 at 1:33 PM
KHLOW2008
  • 41,812 POSTS
Hi 1992b18integra,
Most probably you have a bad head gasket and that is the reason the the coolant are being pushed to the reservoir.
While bleeding the system via the bleeder nut, was it done with engine running or off?
Did you turn the heater to maximum while performing bleeding of the cooling system?
Dec 30, 2009 at 12:16 AM
