Changed and tune up car but still won't start. Battery good, but no spark from plugs...what now? help
Jan 21, 2008 at 11:05 AM
BLACKOP555
✓Experienced Mechanic
first thing to do is check the coil(s) packs and see if they are putting off voltage. if not then you may need new ones. also, you may need a new crank sensor, bad crank sensor, PCU does not know when to spark.
