1992 Acura Integra ignition switch problem
200,000 MILES • 4 CYL • 2WD • MANUAL
PNUT654
I have 92 acura integra. Ignition switch went bad and i replaced it. I started the the car a couple time and put every thing back together. After i put it back together i cant get it to start. i turn in key and only cd player comes on. No dash lights AT ALL come on and it seem not to even try to start. it just clicks. i checked all fuses and battery connection. Please help me out. Thanks
Mar 29, 2009 at 4:10 PM
KHLOW2008
  • 41,812 POSTS
Hi Pnut654, There are a few possibilities for the problem. 1. Faulty ignition switch. The diagram shows how to test the ignition switch.
https://images.2carpros.com/forum/automotive_pictures/192750_IgnitionSwitchTest92Integra_1.jpg
2. Wrong switch. Terminals could be different from original. 3. Connector not securely connected to fuse box.
Mar 31, 2009 at 6:17 AM
PNUT654
Thanks a lot ill check that out
Mar 31, 2009 at 6:41 AM
KHLOW2008
  • 41,812 POSTS
You are welcomed and if you have anymore questions, feel free to drop by.
Apr 1, 2009 at 1:30 AM
MMMS5
I wanted to thank you, for adding the test point guide for the ignition switch, it would be hard to check the ignition switch without it. I took apart the ignition switch, re-soldered the bad connection. and now it's working great.
May 8, 2009 at 10:21 PM
KHLOW2008
  • 41,812 POSTS
You are welcomed and glad to be of service
May 9, 2009 at 6:02 AM
