1992 Acura Integra I dont hear air going in my engine
VEGETO2002
  • 1992 ACURA INTEGRA
Engine Performance problem
1992 Acura Integra 4 cyl Front Wheel Drive Manual
i have fuel and spark but I dont hear air going in I want to know what could be the problem?
Thursday, April 23rd, 2009 AT 7:25 PM
What's the problem here -No start or what?
Thursday, April 23rd, 2009 AT 7:29 PM
VEGETO2002
My starter turns but engine wont turn on I check battery its good and I have fuel going in but engine wont start?
Thursday, April 23rd, 2009 AT 8:09 PM
Get helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, April 23rd, 2009 AT 8:44 PM
VEGETO2002
Ok ill try that and see what happens thank you for your help
Thursday, April 23rd, 2009 AT 9:05 PM
