1992 Acura Integra distributor
153,000 MILES • 4 CYL • FWD • AUTOMATIC
1992ACURA
i just bout a new distributor for my 92 acura an put it in myself i allined everything up the way i was supposed to an it works it will turn over an start no problem. but i hear a slight noise when its running an sound like it comming from the distributor. i havnt takin it for a drive cause im afraid that that noise is bad any ideas
Aug 11, 2010 at 8:23 AM
KHLOW2008
  • 41,812 POSTS
Hi 1992acura,
Remove the radiator cap and check for signs of abrasion. Check if any component is not seated correctly.
If the distributor is rebuilt, get a replacement unit to test.
Aug 12, 2010 at 1:38 AM
