1992 Acura Integra Air conditioning fuse keeps blowing
210,000 MILES • 4 CYL • FWD • MANUAL
AACHICA
I was on the highway and turned off my A/C then turned it back on and it wouldnt cool anymore. the fan was working but no cold air comes out. I checked the fuses and the a/c compresor fuse was blown. so i changed it and it just keeps blowing fuses. What could be the problem? It seems like the compresor turns on because my rpms change when I turn on the A/C.
Jun 8, 2010 at 11:43 AM
SATURNTECH9
  • 30,869 POSTS
How long does it take for the fuse to blow?If it's quick then Unplug the a/c compressor start the car with a good a/c fuse turn on the a/c if the fuse no longer blow's it's your a/c clutch or your compressor.If the fuse still blow's with it unplugged then you have a short in the circuit from your compressor back.Also check when the engine isn't running if the the center of the a/c clutch turn's freely.If it doesn't then you have a problem there.
Jun 8, 2010 at 11:57 AM
