1991 Acura Integra warning light?
98,770 MILES • 4 CYL • FWD • MANUAL
WUFIDO
I don't have the manual for the car, THERE IS A LIGHT THAT IS ALWAYS BLINKING AND THERE IS A BEEPING SOUND THATS ON ALL THE TIME, THE LIGHT IS RIGHT UNDER THE E-BRAKE LIGHT FROM JUST LOOKING AT IT I WOULD ASSUME IT WOULD BE LIKE A HOT EXHAUST LIGHT BUT I DONT KNOW, CAN YOU HELP ME WITH THIS TELL WHAT IT IS AND HOW CAN I SHUT IT OFF? THANKS
Sep 20, 2008 at 1:44 AM
KHLOW2008
  • 41,812 POSTS
Hi wufido,
That should be the catalytic converter sensor.
You need to replace it to rectify.
As to the noise, I am not sure which component is causing it. You need to test and isolate the cause.
Sep 21, 2008 at 3:34 AM
