1991 Acura Integra stop/horn fuse
210,000 MILES • 4 CYL • FWD • MANUAL
MILO1218
ok so i came out side of my house to go to work to find my horn stuck in the on position. So I disconnected the neg. batt. Terminal. Then reconnected it. The horn went out and never worked again along with break lights. I checked the 20-amp fuse under the hood and it was blown. I went and got a fuse and replace it. Thinking this might do the trick. Well the horn didn’t work still and as soon as I hit the horn to check and see if it did work there was smoke from under the hood. I disconnected the neg. batt. Terminal once again and the burning smell and the smoke stopped. I check the fuse I had just put in and it too was gone. Any ideas as to what is going on and why it keeps popping fuse like candy??
willing to pay if i can fix it
Feb 25, 2009 at 10:36 AM
F4I_GUY
  • 3,302 POSTS
There is a short somewhere in that circuit. Check the horn circuit to see if it is rubbing against another wire or a chassis ground.
Feb 25, 2009 at 11:30 AM
