1991 Acura Integra speed sensor
EDDIE40
Electrical problem
1991 Acura Integra 4 cyl Two Wheel Drive Manual
how do i replace the speed sensor,where is it located
Aug 6, 2008 at 10:51 AM
KHLOW2008
  • 41,812 POSTS
hi eddie40,
It is located under the thermostat housing and 2 pcs of 10mm hex bolt + the wire socket is all you need to remove.
Removal of intake hose would make job easier.
Aug 6, 2008 at 8:00 PM
